1 - 10 of 10 Posts
Product Information
Price $99
Rating 5
Average Price $115.13
Manufacturer JB Custom Fabrication LLC
Recommended Yes: 8 / No: 0
Company website http://www.jbfab.net/
Quote and Picture taken directly from JB Fab's website:
Stainless steel twin-stick shifter Made for the Jeep Dana 300 transfer case (5/8" pivot bolt) This transfer case shifter is made specifically to replace the stock shifter. You won't have the problems with our D-300 shifters that you will with "one size fits all" erector set lookin' twin-stick shifters that puts the shifter handles up under your dash! These shifters are designed to be rock-solid you won't find any "one size fits all" brackets held together with ny-lock nuts that are not designed for heat. We use only, all metal, mechanical self-locking hardware. This shifter comes with installation / adjustment instructions, boot, stainless steel trim ring, shift pattern decal, and even stainless steel screws to finish it off! Note: Not all installations / applications are the same, some floor trimming or shifter adjustment might be necessary. MADE IN THE U.S.A.
Discussion Starter · #2 ·
Price $99
Rating 5
Pros Excellent Product, Great Quality.
Cons Slight fitment may be needed.
Recommended yes
Comments: Install was easy instructions were clear. Installation can vary, my tub needed a little modification because of the body lift.
100% worth the time and money.
Price $99
Pros excellent construction nice heavy duty boot simple hook up
Cons i had to reverse some of the hardware to fit my taste where the sticks end up. but not really a con.
the sticks are a bit short to me.
Recommended yes
Comments: excellent well thought out product. everything you need comes with it. stainless for the win. with my install i had to reverse and re-drill the collars that mount on the shift rods to get the sticks to point straight up in neutral. no big deal. just my personal preference. once installed they work perfectly.
the sticks seem too short to me but i just made 2 inch extensions for them. i also purchased their billet knobs those also were very high quality and compliment the sticks
Price $100
Pros very nice materials
Cons they didn't offer a kit to fit my application, so I bought a "weld your own" kit
Recommended yes
Comments: very nice materials used In the kit, came with everything. the billet knobs add a nice touch
Price $140
Pros I like the smooth shift I get over the stock
Cons Wouldn't mind seeing the kit offered in black vs raw stainless to match my trans shifter and maybe a little taller
Recommended yes
Comments: Excellent product for the price! Its made a lot better than other kits and I recommend springing for the billet knobs
Price $106
Pros Easy to install. Works well once installed, great visual indicator of drive status. I used the etched shifter knobs and they look great.
Cons The main bolt the shifters pivot on was too large for the mount on the transfer case. Had to replace it with a thinner one. Simple trip to the hardware store but would have been annoying if I had no transportation.
Recommended yes
Comments: The hardest part of this install was getting the old and supremely rusted single stick assembly out. Had to finally remove the cross member and drop the transfer case down a few inches to be able to reach everything. It took an angle grinder and a lot of torching to get the parts out. The install was much easier, but required a different sized pivot bolt. The one that came with the kit was too large for the holes it had to pass through, by about 1mm. Once installed, the shifters work very well. I'm pleased with the product and the hassle of getting the old stuff out was a good opportunity to change fluids and paint the cross member.
Price $108
Pros High Quality, super easy to install
Cons none as of yet
Recommended yes
Comments: I just bought these, they seem exceptionally well made and include everything you could possibly want in a neat kit form. I am extremely satisfied with how easy it was to install this kit, the bending of the levers is probably the hardest part and that isn't even that hard to do. Pulling off stock parts takes longer than the entire install, but plan to drop your transfer case crossmember down some to get the mounting bolt to clear the tub if you don't have a body lift on your rig.
Price $160
Pros All stainless steel construction
Made in the USA
Quality welds and hardware
Cons None
Recommended yes
Comments: Could not be happier with the JB Fab twin sticks. Quality welds and hardware, plus made in the USA. Solid product and strong design.
You can contact Jon and have custom shift sticks made up to an additional 6" in length.
I went with an additional 4" on my set up and it worked out perfect. I did not have to modify the shift sticks. I did add some tub clearance, but not much.
Great product!
1 - 10 of 10 Posts
