1 - 16 of 16 Posts
Product Information
Price $750
Rating 4
Average Price $252.14
Manufacturer JB Conversions
Recommended Yes: 15 / No: 0
Standard Length Slip-Yoke Eliminator kit.
Discussion Starter · #2 ·
Price $213
Rating 5
Recommended yes
Comments: Great. Install was fairly straight forward, although I'm glad I had somebody there that had done it before. JBC was very helpful over the phone. Instructions were good. I was very pleased with the kit. $213 shipped.
Price $750
Rating 5
Recommended yes
Comments: takes the vibes out and allows ya to raise your skid pate back up and all that good stuff!! definently recomended. got both drivelines built for high angles and high stress by a local company.
She's my density...
Price $200
Rating 5
Recommended yes
Comments: Working great so far! Bearings were easy to remove. Kit came complete except one snap ring was too thick so I had to reuse my old one. Otherwise install was a breeze.
Price $299
Rating 5
Pros Works perfect, quality parts.
Cons Instructions are 8 out of 10.
Recommended yes
Comments: After some research on which was the "best" kit to buy, I picked up the JB offering from Tom Wood's and it is one of the last of the narrow shaft designs. That saved me from having to remove the factory needle bearings in the transfer case like you have to do with 99% of the kits out there. The others work fine, just this one was less work, and I prefer needle bearings myself.
Install was easy, but I got a tad confused reading the instructions as they were universal and geared more towards a TJ. Doesn't take much thought to work through it though. Make sure you use RTV silicone on the splines of both input and output shafts where the yokes slip on. That will minimize the possibility of leaks and was a tip from the pros at TW. Anyhow, the parts fit PERFECT and are well made, but best of all this kit increased my driveshaft length, and got rid of all my vibrations (with TW driveshaft).
Get rid of that TC drop kit ASAP.
Price $200
Pros Shorter JB conversion yoke
32 spline output shaft
Cons None
Recommended yes
Comments: Top notch quality, a must to install a double-cardan drive shaft and a end to drive line vibrations.
Price $199
Pros Easy to install, stronger than stock
Cons none so far
Recommended yes
Comments: Put this in when I did the AX-15 trans swap. So far so good!
Price $300
Pros does the job
Cons none
Recommended yes
Comments: just what you would need for any life above 4". great at drive angle reduction
Price $199.99
Pros Just put it on so I'll let you know
Cons None at this time
Recommended yes
Comments: I just put it on and waiting on a drive shaft so haven't used it yet
Price $230
Pros Strong
Well engineered
Added seal kit
Quality parts used
Cons None
Recommended yes
Comments: Well thought out and engineered kit. It also comes with quality seal kit for the transfer case which is nice since you have it apart already.
1 - 16 of 16 Posts
