Ok so tired of starting new threads when I am doing some thing with my jeep time to consolodate. So I will from now on be posting in this so SUBSCRIBE
opCorn:
Here are some of the links of my adventures so far:
Replacing 305 with 350
http://www.jeepforum.com/forum/f12/replacing-305-350-a-747494/
Gas tank swap
http://www.jeepforum.com/forum/f12/gas-tank-swap-854035/
Auto (700R4) to 5 speed (MG5) swap & TJ Brake booster upgrade
http://www.jeepforum.com/forum/f12/lt1-auto-5-speed-conversion-1430055/
Home brew power brake blead
http://www.jeepforum.com/forum/f12/...r-mc-install-1481752/index2.html#post15008899
On to todays question. Im in the process for gathering parts on for an 8.8 swap. I ran across the teraflex upper adjustable rear shock mounts for $24.99 normally $126.99. Should I jump on it? Does anyone have it? Do you like it? Problems? I know I can build my own, but that seems pretty cheap.
EDIT: seems like these could cause issues with an anti wrap bar. I may have answered my own question
Double EDIT: Inserting to keep first page updated:
Local thread that I use to keep my build updated:
http://www.matanzasjeepclub.org/forum/viewtopic.php?f=7&t=2771
Rig: 1987 AMC Wrangler (Black)
Engine: IROC 5.7L Tuned Port Injection
Transmission: NV4500 MT8 5 speed (internal slave)
Transfercase: NP241C
Axles: 79 Ford HP60, 03 AAM 10.5
Wheels: 17x8.5 Raceline Monster RT232 beadlocks
Tires: 37x13.5x17 Toyo M/T
Lift: SOA HD 0" springs, 1/2" booms
Mods: Updated 6-22-17
Suspension/Steering:
Ruffstuff SOA spring perches
Bilstein 5125 14"/12" shocks
Energy Suspension poly sway bar bushings
NWF Hi-steer arms
Bronze Kingpinbushings
Solid Axle Industries knuckles
Wagoneer pitman arm
1 Ton hi-steer links
Crown HD 6 leaf springs
Ground & Pound ½" Boomerang Shackles
Prothane 1" Body lift
Astro van hydro boost
1.25 bore Master Cylinder
Derale 10" Aluminum
Power steering heat sink
Power steering filter
Drive Train:
Advance Adapters SBC engine mount
Home built above frame transmission cross member with poly bushings
Energy Suspension poly motor mounts
Ruffstuff diff covers F&R
Lube lockers F&R
35 Spline 4340 Chromo front shafts w/ Spicer life joints
Yukon Hardcore lockouthubs
Spartan Locker Dana 60
ARB Locker AAM 10.5
Solid pinion spacerAAM 10.5
5.13 Gears
Seals-it outer axleseals Dana 60
M14x1.5 front wheelstuds Dana 60
Flange Yoke F&R
Cutthroat 4x4 NP241 clocking ring
JB Super Short SYE w/ 1310 CV yoke
Adams CV driveshaft (clearanced CV)
Summit 8mm Wires
MSD street fire coil
Performance cam
Corvette 2.5" Rams horn manifolds
Home built 2.5" mandrel bent y-pipe and Exhaust
Highflow Catalytic converter
Magnaflow Stainless muffler
Home built cold air intake
K&N filter
Outerwears Prefilter
Performance Camshaft
Oil pump pick up retainer
Modified K1500 Transfer case shift linkage
Ruffstuff DIY traction bar
Home Built CV front Drive shaft
Home built Battery tray
DieHard Platinum AGM Group 65 Battery
140A CS144 Alternator
A/C compressor relocation brackets
Sanden 7 piston A/C compressor
Champion 3 Core aluminum Radiator w/ Stainless overflow
Ford Contour Dual Fan w/ FAL variable speed controller
4 Point battery bus bar
Hella accessory fuse block
Mechanical Fuel pressure gauge
Recovery/Armor/Exterior:
Family style roll bars
Skyjacker grab handles
Tow hooks
Warn 9.5XP w/ solenoid box relocation (In cab winch controls)
Home built winch cover
Factor 55 1.5 hawse fairlead
Am-steel synthetic rope
Pro-Link loaded thimble
Pro-comp front bumper w/ shackle mounts
Warrior stinger/grill hoop/winch mount
High lift jack w/ Isolator
Shackles all 4 corners
Barnes 4x4 ¼" flat skid
Home built rear bumper/spare tire carrier w/ 2" receiver
4&7 pin trailer wiring
Smitty Built Snatch block
LED Flood lights
LED Spot lights
LED Eagle eye Rock lights
ARB CKMTA12 Aircompressor
TJ fender flairs
Steel braided front brake lines
20 gallon gas tank upgrade
H4 headlight conversion w/ relay upgrade
Body mounted bottle opener
Under hood tool box
Cowl vent scoop
Interior:
Smitty Built security console
Alpine 9884 CD/Mp3 player
Polk DB461P dash speakers
Polk DB6502 overhead speakers
Polk DB692 rear wedge speakers
Rockville 10" powered subwoofer
Alpine PDX-F4 four channel amp
Dakota SGI-5 signal generator (speedo correction)
Half steel doors & soft doors
Black Quadra-Top
Grant Steering wheel
Autometer gauge bezels
Autometer Ultra-lite gauges with LED lights (Tach, Speedo, Fuel, Vacuum, Volt,Temp, Oil press)
Contour V carling switches (Winch power, Winch In/Out, Engine Fan, Fog/Spot,Rock lights, Compressor, Lockers)
Mastercraft Baja RS seats
Cobra CB w/Firestick antenna
JeepAir A/C
C.RES 2 Cargo net
SpiderWeb Shade
LED interior overhead lighting
Home built wooden trunk deck lid
Future Mods:
LJ stretch
Links/ORI's
4D's
Roll cage
LS Engine
Gas tank swap
NWF Hi-steer arms
Wagoneer pitman arm
Derale 10" Aluminum
Drive Train:
Lube lockers F&R
ARB Locker AAM 10.5
5.13 Gears
Flange Yoke F&R
Summit 8mm Wires
Performance cam
K&N filter
Tow hooks
LED Flood lights
LED Spot lights
TJ fender flairs
Under hood tool box
Cowl vent scoop
Interior:
Black Quadra-Top
JeepAir A/C
C.RES 2 Cargo net
SpiderWeb Shade
Future Mods:
LJ stretch
Links/ORI's
4D's
Roll cage
LS Engine
