Pictures?
I use to repair radios and navigations equipment on helicopters, so circuitry is nothing new. That being said I did not have a schematic and being that this is not a radio I literally hooked it up to a battery and poked around with a jumper wire until I got the desired results. :laugh:Did you have a schematic or do you just know these things?
Awesome!I use to repair radios and navigations equipment on helicopters, so circuitry is nothing new. That being said I did not have a schematic and being that this is not a radio I literally hooked it up to a battery and poked around with a jumper wire until I got the desired results. :laugh:
I would mount the backup light to a piece of wood and use a hole saw on a drill to cut out the right diameter opening. That would leave a nice flat surface to mount on.The next step is to attach them to the stock reverse light housing in place of the bulb socket. The LED lights have a slightly bigger outside diameter than the back part of the taillights (hope that makes sense) so I'll have to cut off some or all of the rear part of the taillight housing.
I'm still undecided on how to attach the motorcycle lights inside the housing. I'm leaning toward something simple like JB weld, but if anyone has a better idea I'm open to suggestions. Unfortunately I don't have access to my shop, so any fabrication work would be crude at best.
Ooh, never thought of using a 3D printer. I need to look around and see if that's an option around here. It's amazing how that technology works, I really think over the next decade it will revolutionize how we do-it-yourselfers fabricate things.I would mount the backup light to a piece of wood and use a hole saw on a drill to cut out the right diameter opening. That would leave a nice flat surface to mount on.
Then JD Weld in or if you have access to a 3D printer, design a flange to mount it in the housing.
You're absolutely right about these lights. The motorcycle lights do make a pretty tight beam and I figured they would. So I held one up to the stock lense and it scatters the light fairly well. One thing I did notice is the stock lenses reflect more light opposite to the position of the bulb. So if I want more light to hit the ground, I might mount the motorcycle lights above the centerline of the reverse light housings.Might do yourself a favor and check out the lights before you do any cutting. Most of those style lights throw more of a "spotlight" beam where you may want to look at a "floodlight" for your application.
