It's me again
- this time a little write up about manifolds
PART 1:
Long, long time ago … in a galaxy far, far away
… hmmmm … maybe not so far, but on the other end of the world, looking from US - some day I've bought an intake manifold from Grand Cherokee WJ - also assembled during the last 2 years by XJ Cherokee. The idea was to assemble it on my 1991 XJ - it was "lying" and waiting for its time, which finally came last Sunday. Also my exhaust manifold was already very loud and I've decided to replace it with other one /not new but in far, far better condition as mine/
This is what I was planning to install
My leaking injectors should be replaced by this opportunity /for those bought on eBay/
So let's start - for the beginning general view before disassembling
After removing hoses, tubes and air filter with its housing it looks similar to this
Disconnect all of electric /2 or 3 plugs on the throttle body and 1 on intake manifold/, detach cables from throttle body and remove it.
If you only want to replace a gasket under manifolds then there is no need to disassemble fuel rail - it's enough to disconnect 2 fuel lines …
… and disconnect injectors - for that the best way is to have a thin, hard needle for moving its clips aside
But if you want to remove the injectors /for replacing them or intake manifold/ then you have to remove the clips by the fuel rail - these are very simple to dismount - simply move them out and be careful not to lose any of it - these are very important holders of the injectors by the fuel rail
After disconnecting all above the fuel rail can be easily dismounted - 4 screws - but BE CAREFUL for fuel draining out after removing rail from injectors !!
Now is a good time to disassemble the power steering pump, that is attached on a side of the intake manifold and has to be taken off
First goes the serpentine belt - loosen bolts A1 to A4 and then turning /CCW/ of B gives belts a space for removing it from pulley
Now the 2 bolts on the back of the pump - in circle on the following picture …
… and 3 more on the front …
… must be unbolted and the pump with pulley and hoses can be put aside
Without disassembling the pump there is no way for taking out one of the bolts holding a bracket to manifold - all of the bolts for taking bracket out are on the following picture
Intake manifold can now be disassembled from head and taken off from the engine compartment - first of all unplug all of the tubes attached to manifold - remember to attach all of them back later! - then you have to unbolt 8 bolts /4 top and 4 bottom/ - these on top are very good accessible with the wrench like this
These 3 bolts /following picture/ are holding exhaust manifold and should not be unbolted at this moment
As you can see the intake manifold "goes" out without problems
Now I could see how is my exhaust manifold broken and why was my Jeep so loud
After unbolting these 3 bolts that I mentioned above and 2 bolts from flange of exhaust pipe, you can easily remove exhaust manifold from engine compartment
PART 1:
