That depends entirely on what the OP and you are calling a rough idle. Unsteady RPMs might be a rough idle to one person while another would only term a misfire as a rough idle. I call 'em both a rough idle... but that's just me. My latest rough idle experience occurred in my wife's 2001 Grand Cherokee and it was cured when I cleaned its IAC. I first gave it to the dealer to fix under warranty & suggested they clean the IAC as a fix... but they insisted it couldn't be the IAC causing the problem as you do... and said it required a $200 throttle body cleaning and fuel injector service. I told 'em to shove it and fixed it in 15 minutes that Saturday by cleaning the IAC.Nonya said:iac wouldn't cause a rough idle,could cause a low idle or high idle.All it does is control idle air flow into the engine.
If I was a Jeep tech and had you come walking into the shop and tell me what you thought the Jeep needed, I think I would listen. Of course, I have observed you helping people for years on JeepForum & Quadratec forum and every once in a while, I see you on other boards. When Jerry Bransford speaks, you best listen. :2thumbsup:Jerry Bransford said:That depends entirely on what the OP and you are calling a rough idle. Unsteady RPMs might be a rough idle to one person while another would only term a misfire as a rough idle. I call 'em both a rough idle... but that's just me. My latest rough idle experience occurred in my wife's 2001 Grand Cherokee and it was cured when I cleaned its IAC. I first gave it to the dealer to fix under warranty & suggested they clean the IAC as a fix... but they insisted it couldn't be the IAC causing the problem as you do... and said it required a $200 throttle body cleaning and fuel injector service. I told 'em to shove it and fixed it in 15 minutes that Saturday by cleaning the IAC.![]()
I'm missing something and I need your guidance. If the Jeep in question, 1998, is FI, how does the Lucus fuel system treatment get to the parts on the TB to clean them?Well i guess if it was that dirty it could mess with the computers ability to set it position and cause a very odd idle.I've never had to clean mine but i use Lucas fuel system treatment in every tank,seems to keep everything clean in the intake.I started using it my my wifes firebird because the idle was high and low,cleared it up and no more weirdness.My jeep has very high mileage 165k plus and the iac doesn't give me any trouble so far.NOW THAT I POSTED ABOUT IT,it will LOL
Considering that not much more than air flows through the intake manifold on a fuel injected engine, the is no chance that a fuel additive is going to do much cleaning around the throttle body or IAC.I've never had to clean mine but i use Lucas fuel system treatment in every tank,seems to keep everything clean in the intake.
On my 2006 Sport. 6 speed manual tranny, 4 liter, my IAC valve does NOT look like the one you are showing Jerry. It LOOKS like my IAC is actually part of the throttle body and after removing the electrical connect, I can not finds the screws that MIGHT hold it to the T/B.The idle air controller is what meters air into the engine through the throttle body when the engine is at idle RPMs when the butterfly valve is closed (which is closed whenever your foot is off the accelerator pedal).
It's held onto the throttle body via two T-25 bolts on the engine-side of the throttle body. I don't doubt the Chilton's manual doesn't cover it well, I consider Chilton's and Hayne's manuals little better than nothing.
Remove the IAC via those two screws and then clean its solenoid actuated plunger gently with aerosol throttle body cleaner and a toothbrush. Use a small brush like a baby bottle brush to also clean the oriface (opening) the plunger fits into which is how the air gets into the throttle body. If either is dirty, air can have trouble getting into the engine when the engine is idling.![]()
You might think that but think carefully...how to you think those passages and different parts get carboned up if only air runs through them?Considering that not much more than air flows through the intake manifold on a fuel injected engine, the is no chance that a fuel additive is going to do much cleaning around the throttle body or IAC.
Ok if it doesn't combust in the intake then please explain the combustion by products in the intake and iac etc.Inquiring minds want to knowThat fuel combusts in the manifold
Well it doesn't exactly combust in the manifold. It only combusts when it is ignited which happens in the cylinder under compression.
But we know what you mean.
Maybe it's blow-by coming through your crankcase breather?Ok if it doesn't combust in the intake then please explain the combustion by products in the intake and iac etc.Inquiring minds want to know![]()
Have your inquiring mind review the operation of the crankcase ventilation system. And the EGR system, if so equipped.Ok if it doesn't combust in the intake then please explain the combustion by products in the intake and iac etc.Inquiring minds want to know![]()
Maybe or are you sure?How does the blowby cause the iac passages to get carboned up?Maybe it's blow-by coming through your crankcase breather?
Don't you think your intake manifold would run a little hotter than it does if this were the case?The manifold has constant combustion taking place in it but the open cylinders are constantly pulling it back in.
Maybe the "wet system" keeps it cool!!!Don't you think your intake manifold would run a little hotter than it does if this were the case?
Yeah i just learning about them...please tell me more.Don't you think your intake manifold would run a little hotter than it does if this were the case?
No offense, but it sounds like you don't have a very firm grasp on how internal combustion engines work.
