Figured I would do a write up and make it as detailed as possible so that people see how to upgrade their 4x6" speakers to 5.25" up front in their TJ. This is a decent improvement over the stock speakers when done and I was very pleased with the end result. The main issue with the stock speakers was that as soon as I turned up the music a bit up, the fronts would rattle this was because the screws were loose and the speakers just plain sucked for any decent music output.
It is a fairly straight forward procedure but it does involve some cutting on a little bar inside the dash as the 5.25" speaker is oval so its not a simple plug and play. This guide is good for 97 to 06 year TJ's.
This install took ~2hours and I took my time and I even had a bite to eat in between.
Tools needed:
Philips Screw Driver
Allan Head Screw Driver
Pliers
Wire Strippers
Dremel or some sort of hack saw in order to cut steel beam - Dremel recommended
5.25" NalinMFG speaker adapters
PolyFill
5.25" Speakers of your choice
Another member mentioned that he used 18 gauge tin-snips to cut the steel beam off instead of using a dremel. So if you don't have a dremel guess you can try tin-snips.
There is a variety of adapters plates online and they range from 10-20$. I really did not want to go with some plastic ones due to maybe cracking or rattling so I opted to go with the NalinMFG. I had previously read some good reviews about them and figured why not give them a try considering they are 14g CNC laser cut steel. These plates will also fit ANY 5.25" aftermarket speaker. The quality of these adapters is really superb and solid. In your package you receive two (2) adapter plates(driver & passenger), (8) #8 machine bolts, and (8) #8 nylock nuts. and you really can't beat the price of $14.99.
Procedure:
Okay, here we go.
1) Start of by removing the 2 Philip head screws
2) Once removed you will find your speaker setup. As you can see from my pictures this was quite a ghetto setup. Remove the 4 or however many screws hold your speakers.
3) Once the speaker is removed, you will be left over with other adapters/random stuff perhaps like me. I removed everything and just left the bare steel framing there. Because the NalingMFG adapters bolt straight into the steel frames holes you don't need any of this extra stuff.
4) This is the tricky part, this is what you want to cut as much as possible off in order to fit the speakers in. It's quite heavy steel so get your dremel out and start cutting. This was the longest part of the entire upgrade. And I highly recommend to use the dremel as it makes the job fairly easy. It was a bit hard getting the dremel in there due to space constraints but I managed. Also I did remove the glove compartment to make things easier.
You also might want to put something in the rear because there will be sparks flying, I had this towel lying around, soaked it a bit with water and covered the rear so no sparks would get anywheres and damage anything.
Once you cut one part off you can easily bend it at the upper portion, this will make it a lot easier to get to. Also you can probably just cut a bit at the top and wiggle it until it breaks off if your in a hurry. Here is a picture of the bottom all cut.
5) This is what the end result should look like when you finish taking the bracket off.
And here is how much I actually cut off from the actual steel framing. I had no issues fitting the speakers in afterwards.
6) After this it's pretty straight forward and you just have to attach your speakers to the bracket and screw the bracket on and connect the wires.
Here are the speakers that I had picked up online. They are Polk Audio DB521 5.25". They came with screws but I did not have to use them at all. The nice thing with these speakers is you can move the tweets around and position them at different angles of your liking.
7) Use the screws provided that came with the adapters plates to attach your speakers to the plate itself.
8) After the speakers are mounted, you want to connect the speakers to your existing wires. IMPORTANT: Usual colour code is the wire that is striped (red/white) is the (+) and the solid colour wire (white) is the (-), you don't want to flip the polarity on the connections you could ruin your speakers. If your not sure what's what, before disconnecting your old speaker look carefully and you should see a small (+) and (-) on the board so make notice of that.
The speakers I bought came from a 04 TJ so they already had the pigtail on them for straight connection, but I just cut those off and spliced in the wires.
If your upgrading in a newer TJ, I guess this would of been just straight plug and play setup.
9) Start sliding in your speakers into the hole and it should be a easy fit if you have removed enough from the steel frame.
And here is a picture of the speakers actually mounted on the frame. Nice and tight and there should not be any rattling.
Optional: Polyfill
I read online that polyfill helps with keeping the sound waves from bouncing around. Especially since the TJ is not that great of a vehicle for sound any little bit helps. You can pick up polyfill at walmart and it was like $5. I just kept stuffing it in until I noticed it was getting really full back there.
Conclusion and Thoughts:
Overall this upgrade cost me just under $80 for the speakers and the plates. Personally think it was well worth the price especially since we all listen to music on a daily basis in the Jeep. Driving the Jeep earlier tonight I noticed it sounded a lot more balanced inside and almost as fell I was being hit by music all around me and not just coming from the sound bar.
The NalinMFG Adapters were wonderful and of high quality and they were designed to be a perfect fit. I would highly recommend these for anyone planning on doing this upgrade. :2thumbsup:
And here is a couple of images from the finished product. If you have any questions or if something is not detailed enough please let me know. Cheers.
Tools needed:
Pliers
Wire Strippers
PolyFill
Image uploading. Refresh page to view
Procedure:
Okay, here we go.
Optional: Polyfill
