With the steering in the 1997 Jeep Grand Cherokee i drive getting progressively worse and worse i decided it was high time to fix the issue. I asked questions about various aspects of the steering gear and i was promptly referred to obtaining a rebuilt steering gear, so i investigated the various rebuilt steering gear products out there and found out that a high percentage of people purchasing the rebuilds were rather dissatisfied with the quality and or had a high failure rate.
With that said i decided to go by the old axiom, if you want it done right, do it your self and purchased a used steering box out of a 1998 Jeep Grand Cherokee from a junk yard out west, had it shipped to me and with the gracious generosity of my friend (who choose the steering gear personally) was able to use his facilities (barn) and tools to tear down the steering gear.
Although he didn't have all the tools required and after careful research and pricing of said tools i came to the realization that they were quite overpriced for what they were, yes call me cheap but necessity being the mother of invention so to speak i decided to make a few of the tools as you will see!!!.
Since there's a few vague how to's on the Saginaw steering gear out there i decided to make my own in hopes this will provide enough information for the do it your self mechanic to successfully disassemble the ZJ steering gear.
Here's my victim, um err steering gear, as you can see its in really nice shape cosmetically, i did do a few torque tests on it and found it to be a bit loose but still within specs.....
So with that said, let the fun begin!!!
Took a bit of work but i managed to get the pitman arm off the box.
First thing i did was to take the retaining ring off securing the housing end plug. There's a small hole on the side of the housing where the side of the ring can be accessed to dislodge it from it's seat, use a punch and hammer to break it loose.
(NOTE***) if the clip end is not near the access hole it will be necessary to rotate the ring around till the end of the ring is near the access hole, this makes it easy to get a hold of the retaining ring end for removal.
Remove the preload adjuster nut.
Remove the 4 side cover bolts.
Back out the preload adjuster bolt.
