Is this any help A1?2001 jeep Grand Cherokee WJ with 4.0. I replaced a missing grommet on the transfer case shift cable . Upon snapping the cable back onto the lever, (under the car) the shifter will not stay in 2 wd. It is in 4 wd pt. It will go into 4wd ft if shifted. Try to put it into 2wd it will not stay there but move and retract back to 4wd PT. I am assuming it need the cable adjusted unless something else happened when the grommet fell off. Any help appreciated
