41 - 49 of 49 Posts
Price $600
Pros tight to body to not lose approach and departure angles, 1/8 plate re-enforced in the front for weight. 1/4 for beef and add weight to rear, rear built to match stock look of original bumper.
Cons not easy getting the light sockets to blend in.
Recommended yes
Comments: I can build to order. 225-721-0378
Price $200
Pros Well made and serve as OBA reserve tanks
Cons rear bumper latch design not completed
Recommended yes
Comments: Built these bumpers from materials in the Spring of 2004. They are well crafted and have held up to years of trail use without issue. Both bumpers are tanks for the on board air setup I have, the design has worked well for nearly a decade now.
Price $20
Pros Tough, looks great, custom for cj frame and dinosaur Ramsey, D-rings, lights
Cons Only fits dinosaur Ramsey, new winch =new bumper
Recommended yes
Comments: Was an easy bumper to make for my first one. Paint was cheap and is easy to touch up. Should have built to fit more than one winch.
Price $0.01
Pros Tough. Custom
Cons Have not mounted a winhc plate or D rings, Yet.
Recommended yes
Comments: It is great to build your own bumper if you have the ability too, more custom, better fit for what you need it, and you can always add to it (or cut more off if need be).
Price $0.01
Pros priceless, doing it yourself with kids.learning,trade and skills. handing down passion of fixing/ building it yourself.
Cons none
Recommended yes
Comments: :cheers2:21/2 in 1/4 wall tubing , from scrap bin at work.
Price $1
Pros D-bolt brackets, hitch mounts front and rear, take a tree pretty well
Cons Sometimes get smaller trees caught between bumper and fenders
Recommended yes
Comments: Homemade,, I bought it with the bumper on it
-N7PBJ
Price $3.5
Pros Flush receiver, full front uni-frame tie-ins, 3/4" shackle tabs, pure beef.
Cons 197 lbs (before paint)
Recommended yes
Comments: As the designer/fabricator of this bumper I may be biased, but I'm still happy with the design & function.
41 - 49 of 49 Posts
