Holley Truck Avenger
14016 19
Product Information
Rating 4
Average Price $305.26
Manufacturer Holley
Recommended Yes: 19 / No: 0
4BBL
1 - 20 of 20 Posts
Discussion Starter · #2 ·
Price $270
Pros High Output, good mileage for a carb, clean and easy to work with
Cons Floats got stuck open when I first ran her, not FI
Recommended yes
Comments: 670cfm - The application I am using with for is a 89 YJ with a AMC 360 inside. Mainly my daily driver but also used to have a little fun now and then. Seems to run smooth, good on cold starts, doesn't seem to east as much fuel as other Truck Carbs. I have a "Jeep" billet air element with a 13in. K&N Oil Air Filter on it (E-3698 if you were wondering)
Price $480
Pros better throotle response,better accelerations
Cons worse MPG,need adjustment or tuning to work it right
Recommended yes
Comments: never float again when on the hi inclined and lean off road obstacle,better throotle response,better accelerations,but worse on MPG,needs to tuning for work it right n good MPG......especially on main jet,it's to big.....for AMC 258 cid I6.....even on engine w/ moderate modification,such as camshaft,4.0L head,and MSD ignations.....
Price $200
Pros easy to tune and parts are easily obtained locally, makes me smile when i push the skinny pedal
Cons none that i can think of
Recommended yes
Comments: excellent fit and finish, bought mine used so it needed a rebuild but again a joy to work with, runs 10 times better than stock
Price $375
Pros Automatic choke works well
Cons 650 double pumper.. actually dumps a little too much fuel to the 304, had to re-do jets
Recommended yes
Comments: As the list is limited..
What I have is actually a 650 double pumper.
Sit's on a AMC 4barrel intake. Had to redo jets to prevent rich running & flooding problems
Price $350
Pros Lives up to what holley says. Resists bogging well.
Cons I had a hard time dialing it in. Always wants to run rich. Probably a bit to big of a carb, even for a stroker?
Recommended yes
Comments: Good Carb but a lot of tuning comes with it as you may know. Hasn't bogged on me and good throttle response. No real complaints once I got it tuned properly.
Price $1
Pros Awesome carb off-camber... was going to TBI my engine, but now i am not wasting my time and money 670T/A is the ****!!!!
Cons none
Recommended yes
Comments: It works awesome... never floods no matter how long it stays nose up or nose down... sideways... awesome throttle response... fuel mileage is comparable for any 350 SBC...
Recovering Bronco Rider
Price $150
Pros Poor mans EFI.
Cons None yet
Recommended yes
Comments: Buy the re-manned unit, or wait for a sale. MSRP of $450+...puleaze! Got my 770 for $150 on ebay. Called and the guy & he hated it. My bud is a old dirt tracker. The jets were Huge, like it was set-up for alcohol! Since I've only had dyno time on it, and it made over 400hp I'm happy so far. Seems easy enough to tune/jet which I'm sure I'll have to do for street/trails.
(It even has the vacum port for the tailgate switch;) )
Price $400
Pros just awesom
Cons not for a stock engine
Recommended yes
Comments: good product very pleased with it
great up steep incline
good downhill
great on angles
Price $399
Pros Can run steep hills without flooding/sputtering out.
Cons Hurt mpg... lol. (like it was great before)
Recommended yes
Comments: Poor man's EFI. It is amazing how well this carb does at extreme angles. It is night and day from my old edelbrock. So far it hasn't been the reason I back down from a hill. I wish Holley offered a 570 cfm model. The 670 was a little much for my 355 sbc but after rejetting and tuning it works well. I would highly recommend this carb.
Price $250
Pros Awesome!!!! Easy to tune. Runs like a top.
Cons None
Recommended yes
Comments: I bought this used. It took a little tweeking but I got it back to stock specs and tuned from there. It sits on top of an AMC 360 and this carb made a huge difference in performance over the Edelbrock that was on her when I bought her. Not to knock Edelbrock because it was in pretty bad shape.
Price $375
Pros Great carb. Starts right up. Not stalling on inclines.
Cons Price - but get what you pay for. Had a edelbrock 650 on it before- always had a float issue from the start out of the box. Was great on the road, get off road was a awful carb.
Recommended yes
Comments: Current set up is Holley 650 with edelbrock 2130 intake manafold.
1 - 20 of 20 Posts
