"Never let someone tell you that you don't need more horsepower. Just stop talking to them, who needs that kind of negativity in their life?"
If you missed the main phase of my build, you can find it over here: High travel, high clearance & high octane, a streetable adventure LJ story. I'm still posting non-engine related build updates over there so if you're interested in that type of thing too I suggest you follow both threads!
Ever since I rode along in some Jeeps desert racing and put the supercharger on my Jeep I've turned into a bit of a horsepower junkie. Because ending an addiction is no fun, my methodology here is to throw the biggest, baddest, strongest engine (that doesn't compromise my main build goals) under the hood of my LJ and not be left with wanting anything more.
Unlike the main phase of my build which I received a lot of direction on from MrBlaine and was able to base my build on many many iterations done before mine, this engine phase of my build I'm going to be upfront that I have little to no clue what I'm doing. Don't tell anyone but the most engine speak I do is smiling and nodding when guys talk about their engine's lift, timing, compression, litres, etc -- yeah, I have little to no clue what any of that means. HP/TQ charts are about as far as I understand. I'm sure as I do this engine swap that there will be things that work well, things that could be done better but aren't worth redoing, and things that need redoing. This is new territory for me.
My goals are:
My goals are:
- Reliability is priority.
- Not compromising phase 1 of my build is non-negotiable.
- Cramming as many ponies under the hood as I can.
- Torque and HP curves need to work well for my uses and not focus solely on peak horsepower.
