Also, this is just laying by the coolant reservoir- what is it and should it be connected to anything?
That is the end of the vent that comes up out of your differential. The round star shaped end fitting slips on over the top of one the shock strut nuts that is directly under that coolant tank. Its not broken and is quite easy to slip back on over one of those three nuts.Also, this is just laying by the coolant reservoir- what is it and should it be connected to anything?
I'm not seeing any coolant higher than the top of the oil pan, so nothing on the block dripping down.The heater lines run behind the motor so it could be that. The second picture is the differential breather, It snaps on top of the strut stud.
