Be better to replace the dimmer switch and install relays. for the headlights
Almost everytime there is a problem like yours, it is the floor switch. I had the same problem but on mine it was the plug to the floor switch.can anyone tell me what the two wires are that were just hanging there? maybe this is my issue?
why would the dimmer switch be of concern? is it known to cause this symtem or are we just throwing parts at it?
Not suggesting throwing parts at it, just giving you first hand knowledge from experience.can anyone tell me what the two wires are that were just hanging there? maybe this is my issue?
The orange is a power feed for the dome light and the black is the ground for the dome light. Not being used will not effect your concern.can anyone tell me what the two wires are that were just hanging there? maybe this is my issue?
thanks for the insight on the unused wires!The orange is a power feed for the dome light and the black is the ground for the dome light. Not being used will not effect your concern.
As stated, wiggle the connector and switch on the floor to determine if it is that or the actual headlight switch on the dash. Also, checking and cleaning grounds on a CJ is never a bad thing.
Nope, didn't find the short, or more specifically, I found one short. It is still going off intermittently, but not as often.Sounds like you may have found the intermittent short that was causing it. As wired, one wire feeds both headlights.
The momentary circuit breaker is a safety feature, no fuses in the headlights. Any flashing at the headlight indicates a short.
They work better with relays but you also should be putting in momentary circuit breakers on those new power circuits. Some put fuses in, but then you should have 2 relays so your 5c fuse is not going to cause a crash.
