I bought one for a specific woodworking job that I thought would be easy. The thing fell apart just as I was finishing the final cut (of about 30-40).
It got the job done but just barely. I won't buy one again, they just aren't built to last at all.
As for holesaws, what you want is a bimetal blade. Milwaukee, Starrett, Lenox, any should do but sometimes the teeth of the blade are bent out too much and they will cut better and grab less if you grind the outside teeth so they don't stick out so much.
Better than that, forget hole saws and step up to rotary broach cutters. That's the Cadillac of tube notching cutters and used properly they can make clean fishmouth cuts in thin wall bicycle tubing without collapsing it.
If you are a pro, get pro level tools. If you aren't, and can't resist Harbor Freight, plan on using the warranty.
