Ground strap
133 4
can anyone tell me, there is is a ground strap that is attached to the firewall on my 95 Jeep Wrangler. I traded a hotrod VW for this Jeep.
so the strap ground looks like at one time it burned. Although it is intact. Is this something I should be concerned about?
1 - 5 of 5 Posts
2011 Jeep JKU
Pics? Are you saying its not there, or there but damaged, or just appears damaged?
Also, you want to post this in the YJ tech section, perhaps a mod like @jbolty Can move it for you
Hoss
2011 Jeep JKU
Those are factory, IIRC, one goes to engine, and the other to frame?
They are under $10 @ FLAPS, not a terrible cost, and easy to replace.
Probably not a bad idea to change it out
Hoss
There should be. I don't remember where exactly it attached to the original engine though....I have a GM V8, and bolted it to the main engine harness ground behind the intake, along with the main body ground wire from the Jeep bulkhead connector. When dealing with a YJ, ground ALL the things lol
Automotive tire Bicycle tire Rim Electrical wiring Automotive exterior
1 - 5 of 5 Posts
