I just bought a 2003 Rubicon, with a manual trans. I just want to make sure I understand the vehicle before I make a mistake.
So when I am in 2H and want to go to 4H, it says you can **** on the fly, does this mean you don't even have to take it out of gear, just depress the clutch and pull the lever into 4H? Likewise the manual says to shift into 4L, it's best to do so at 2-3 mph, the manual does not make the rest clear. Can I get the jeep moving in 1st gear, 4H, depress the clutch and shift into 4L with the gearbox is still in 1st gear, or must the gear box be also put in neutral.?
Thank you
Thank you
