I've been told by multiple sources (some working on the chemistry side of the oil industry, specifically for Sunoco) over the years that this is a fallacy.There is such a wide variety of fuel that You may want to run 91 every once in awhile just for the cleaning additives.
Here's another good reference:Gasoline Factors That Matter
The quality of gasoline and the additive package usually affect the rate of engine wear more than the octane rating. Basically what this means is that it matters more where you buy your gas than which grade you purchase.
Regular Unleaded Gasoline
The recommended gasoline for most cars is regular 87 octane. One common misconception is that higher octane gasoline contains more cleaning additives than lower octane gas. All octane grades of all brands of gasoline contain engine cleaning detergent additives to protect against engine deposit build-up. In fact, using a gasoline with too high of an octane rating may cause damage to the emissions system.
Run the recommended octane to maximize power.Will Higher Octane Gasoline Clean Your Engine Better?
As a rule, high-octane gasoline does not outperform regular octane in preventing engine deposits from forming, in removing them, or in cleaning your car's engine. In fact, the U.S. Environmental Protection Agency requires that all octane grades of all brands of gasoline contain engine cleaning detergent additives to protect against the build-up of harmful levels of engine deposits during the expected life of your car.
Thats old school, went out in the 90s. I had a '70 340 duster that would not run at all, let alone ping, on low octane fuel.run 87. higher octane is for power only.
if you hear a "pinging" from the engine - then up the octane to the next level. Its rare though that you really need it.. (I had a 68 camaro that HAD to have high octane..)
All Fuel injected Harleys since... oh.. at least 2000 have pre-detonation sensors, and all HDs have had FI for a few years now. Thats a lot of motorcycles. My 1995 Ducati does.... just about any bike or vehicle with an engine computer and fuel injection senses pre-detonation in one way or another, usually not the old style knock sensors however. Waiting for the detonation is to late, damage done. There are many vehicles still out there with old style knock sensors, however.I know for certain that most motorcycles and marine engines don't, so it's still applicable.
:laugh::rofl: ya'know.. now that you mention it, been a loooong time since i have heard that!Thats old school, went out in the 90s. I had a '70 340 duster that would not run at all, let alone ping, on low octane fuel.
Uhhhhh NOPE, well maybe not a nope, but a bit of a qualified nope, you touched on it toward the end, but your statement is still too broad.All Fuel injected Harleys since... oh.. at least 2000 have pre-detonation sensors, and all HDs have had FI for a few years now. Thats a lot of motorcycles. My 1995 Ducati does.... just about any bike or vehicle with an engine computer and fuel injection senses pre-detonation in one way or another, usually not the old style knock sensors however. Waiting for the detonation is to late, damage done. There are many vehicles still out there with old style knock sensors, however.
Anyway the WK2 detects pre-detonation and adjust accordingly. You wouldn't know its working. It will throw a code only when the adjustments go out of range.
My bad - I came back from a run and did some research. You caught me as I was trying to edit my post.I think we have a failure to communicate. You seem to keep wrapping your head around a knock sensor an that was not what I was saying. I did not mention knock sensor, but a what is commonly called a predestination sensor or prediction algorithm.. Nothing like a knock sensor. Harley users a what the call an ion sensor system.
Bottom line is that, for the WK2, listening for ping and hearing none gives you false information.
Well, a year or two ago, last time we checked into it on the XLforum that logic was NOT used in the Sportster ECMs. That might have changed by now, but I haven't heard of it.Harley users a what the call an ion sensor system.... That is also used in many new sportsters.
