1 - 20 of 216 Posts
Let's start with a picture showing the reason this all began. I have to admit this was the best rollover I could have had. :shhh:
Note: This is what it looks like today
Tire Wheel Automotive parking light Vehicle Automotive tire
Motor vehicle Vehicle Automotive exterior Automotive design Auto part
I finished putting a GR8 Half Top on my LJ and thought I would share it. All in all the entire project went pretty well. Only A few minor setbacks along the way but nothing to serious.
Special thanks to my buddy Jim, your knowledge and time is greatly appreciated!!
They have a standard and an extended version of the top which is 2 1/2" longer. This is the extended top.
One of the toughest parts was making sure to drill the holes in the correct spot to run the roll cage through. You only get one chance so you have to get it right.
The bulk head fits nice and tight. Sealed it first with camper tape and then with a urethane sealant. The factory drain holes and seat bolt holes drain the bed quickly when it rains.
Inside view of cage going through the top.
:drool: good job :cheers2:
Question though,
Since you have the cage running through the top like that, no bolt connection near the top (that I can see), you have to remove the rear part of the cage to pull the top now, correct?
Wow, that looks really great, and it looks like the construction on the cage and top is really solid.
Discussion Starter · #9 ·
Question though,
I have tube clamps near the top that you can't see in the pictures. Two bolts at the top and the two bolts at the tub and the bars come off. Then you can remove the top and reinstall the rear tubing and you can run topless. Takes about 15 minutes max.
Ooooo. Very nice! :thumbsup:
That looks great, Im really jealous, if I had the money I would 100% do this. Great job!
Your Jeep is so awesome :drool:
I'm a big fan of red Jeeps with silver moabs if you can't tell :D
Discussion Starter · #18 ·
Just wanted to say "Thank You" to everyone for the kind words. I appreciate it very much. :thumbsup:
1 - 20 of 216 Posts
