ok lets figure this out
this is a 1995 CHEROKEE XJ and I'll guess a 4.0L engine and an automatic trans....
When you turn key the engine cranks* - yes or no?
Yes spins fine sometimes it cranks then idel few minutes then die then won't crank one time it crank an I touch the tps sensor an it died try crack again no luck but does trun over fine
Also did a code ck have 11 an 12 12 battery been disconnected an thank that 11 is a crank or disruptor plate change out crank sensor.ot crank after that but died again.
Jeep Enthusiast Forums
