Well it seems that my Jeep's (97 TJ) issues and repairs have gotten over my head. After finally getting the fuel system, battery, starter, and other small issues resolved I thought I finally had a running Jeep again. I decided I should do a full fluid change out since I didn't know when the previous owner had last changed anything. When I pulled the rear differential cover off "chocolate milk" poured out and I saw several broken teeth on my ring gear. I didn't feel any metal in the oil and I ran a magnet around inside the differential and didn't see any particles sticking to it. After seeing this I decided that I was in over my head and dropped my Jeep off at East Coast Gear Supply to have them rebuild my rear axle and troubleshoot the odd sounds from my front end. They contacted me confirming that I'd need to replace the ring and pinion as well as needing new bearings and seals on my rear Dana 44. I also had the ARB air locker rebuilt while they had it open. ECGS contacted me again to let me know that my front Dana 30 has a broken u joint, blown driver side seals (saw it leaking from the drive over) and could possibly be bent, I will know more on Monday when they continue to work on it. Now I need some advice weighing some different options. Should I sink around $1500 to rebuild the front axle assuming its not bent (maybe add a truss), should I look at buying a "bolt in" TJ Dana 44 (G2 with ARB? $3700) online and installing that myself, or ECGS quoted me $5400 to install and brand new JK dana 44 with arb locker, chomoly shafts, ect. I'm also open to other ideas/suggestions.
I planned on primarily taking this jeep on trails around VA/NC area and I don't plan on rock crawling or being heavy with the gas pedal. I thought I had gotten a good deal on Craigslist but I think I unknowingly inherited the previous owners issues. I've pretty much driven this jeep a few miles back a forth to work and then did one wheeling trip on my friends farm mainly going through woods and horse pastures.
I like the 35" tires and 4.88s currently on my jeep and eventually I'd like to add a PSC hydro assist kit along with the currie steering parts.
