For Sale:
Front axle out of a 1999 Jeep Grand Cherokee Limited with QuadraDrive.
This axle was just pulled out of my Jeep a few days ago. It has a VariLok / HydraLok differential with 3.73:1 gears. It was whining, so it probably needs pinion bearings. Other than the whine, it was working fine. I had recently replaced the upper control arm bushings with OEM Mopar bushings, and replaced the ball joints with units from Advance Auto Parts. The Jeep was driven less than 100 miles after these parts were replaced, and then I swapped out the whole unit. The spring perches are rusted out, but I have a set of the bolt-on Doman replacement perches that can go with the unit.
Asking $250/OBO. The axle is in Coeur d'Alene, ID. I cannot ship. This will need to be picked up.
I also have a set of CarQuest premium axle shafts for this application that also have less than 100 miles on them.
Asking $100/OBO for the pair of axle shafts.
I also have some miscellaneous parts, including good used control arms, tie rods, and springs that will work for Jeep WJ Grand Cherokees that are available.
Let me know if you have any questions.
Thank you.
