I'm working on a rust repair/strengthening of my DD Jeep WJ. I've found a couple pinholes in the frame rail above the rear lower control arm mount. I've also found a significant amount inside the framerails in that section. No replacement sections are available that I've been able to find.
My repair plan is twofold. One, remove and treat as much rust inside the framerails as I can. Second, install frame stiffeners from the front LCA mounts to behind the rear coil spring buckets.
To accomplish this, I've sourced IRO frame stiffeners for the center(front LCA mount to rear LCA mount) and Trail Forged rear wheel well frame stiffeners for the rear wheel well area. That leaves an 1'-2' section, in between the sets, where a body web usually exists(removed due to rust and prepping for replacing it and replacing the rockers.) I'll be making my own stiffeners to cover this section.
My big concern is that the IRO parts are 3/16" steel and the Trail Forged parts and parts I'll be making are 1/8" plate. That leaves the change in thickness and likely stress riser at the worst point, as that's the part I'm attempting to strengthen.
