While leaving my motel out in the desert Saturday morning, my O4 TJ 42RLE transmission suddenly caused my tires to chirp and the engine to die when I came to a stop. The usual first suspects were checked. The ATF+4 fluid level right where it should be and it was bright clean/clear red. I then reset/cleared the main computer then reseated all the connectors for it plus the TCM (transmission control module) which is separate from the main computer.
Ended up having AAA put my TJ up on a flat bed and I rode in their truck for the 185 mile trip home. Fortunately that was free since I had recently bought AAA's Premier package which includes 200 miles of towing. Without that the AAA driver estimated it would have cost $1600. I dodged a bullet for sure.
Anyway, Blaine Johnson was kind enough to loan me his TCM out of his '04 as a quick test to see if it was something simple. Nope. The P0755 code my external reader produced (the built-in computer just generates a catch-all P-0700) didn't make me think the TCM was the cause but it was worth a shot. Same symptoms after trying his computer. It's in Limp Mode... won't shift and occasionally somehow locks the torque converter (I think) so the engine dies when I come to a stop. So I removed his computer and reinstalled my original.
Anyway, the P0755 code decodes to a bad 2/4 solenoid. That solenoid is in the Solenoid Pack p/n Mopar 4800171AA. Doesn't look difficult to replace from what the FSM says but then I've never spent any time inside an automatic. At least that solenoid p/n is not as expensive as I feared, plus the OE Mopar solenoid pack I need is sold all over the place including eBay and Amazon.com.
Questions:
1) Any gotchas to replacing that solenoid pack for someone reasonably ok with small complex stuff but isn't familiar with an automatic transmission's insides?
2) The FSM says a DRB must be used to perform the "TCM Quick Learn Procedure" when the solenoid is replaced. I don't own a DRB since they're expensive so is there a way around that or am I going to have to take it to a shop that has a Chrysler DRBIII tool? Will I be able to drive there (5 miles) without having done that to have a shop perform the Quick Learn routine?
3) Has anyone with the P-0755 code not had that issue resolved after replacing the solenoid pack? Googling it brings up plenty of examples where nothing else was needed to effect the repair. Could that solenoid also be the cause of the tires chirping/killing of the engine when coming to a stop or shifting into Drive? No guesses here please.
Any comments from anyone who knows the 42RLE and hopefully has had that rather common P0725 code would be gratefully appreciated.
Fortunately this is not my daily driver so I'm not under any pressure to get it fixed right away.
Questions:
