Status
Not open for further replies.
1 - 1 of 1 Posts
· Premium Member
The JK with stock wheels, no spacer, no lift
32" tires: no rubbing
33" tires: some rubbing
35" tires: don't try
The JK with stock wheels, 1 1/4" wheel spacer, no lift
The JK with stock wheels, 1 1/2" wheel spacer, no lift, Bushwacker flat-top flares
33" tires: no rubbing
35" tires: rubbing that can be cured with trimming pinch-seam
37" tires: don't try
The JK with stock wheels, 1 1/4" wheel spacer, 2" lift
35" tires: some rubbing
The JK with stock wheels, 1 1/4" wheel spacer, 4" lift
35" tires: no rubbing
37" tires: some rubbing
38" tires: be careful
39" tires: don't try
What kinds of wheels can I run on my JK?
Of course, any stock wheel that comes with the JK will be able to be used. If you are looking through the junk-yard and you find some rims that you really like, make sure that they are a 5-bolt pattern on 5" diameter. Chevy 1/2-ton pick-up trucks in the 2wd variety use this bolt-pattern.
You will be able to fit some 15" rims and all 16" and bigger rims on your Jeep. The only problem that you might run into is the brake-caliper rubbing on the inside of the 15" rim, depending on off-set. If you find the rims you choose rub - a set of wheel-spacers can be installed to move the rim further from the caliper.
Check the tire-manufacturer's recommended rim-width prior to running the tires on the rims that you choose yourself.
Note: This chart will be updated as people report back on different lift / wheel / spacer combinations. If you try a combination that works that isn't listed here yet, please send me a PM with the details of the lift and I will update as soon as possible
1 - 1 of 1 Posts
Status
