Thanks i will chack the float, Although i did adjust it to 8mm if i remember correctly. Its the old carter yf i know it need a rebuild anyway.You can always check timing but I would suspect carburetor float level issues.
F-head with a timing chain? What kind of wizardry is this? Last time I had mine apart it was nothing but gears.Hi,
I'd check the timing. The mark should be solid, if the mark moves around while at idle the chain is shot and should be changed..
good luck take care be safe
tim
OOps My Bad Fourtrail... I have my Flash shirt on and I guess I was ASSZOOMING .. I haven't had my F head apart and wasn't aware they were a gear drive.. Thanks for the information when I have to take it apartF-head with a timing chain? What kind of wizardry is this? Last time I had mine apart it was nothing but gears.
