Hey guys, I'm somewhat of an old poster here. I bought my first GJC a few years ago and promptly totaled it driving home due to a new driver pulling out in front of me. I drove it for several years, mostly wheeling as it wasn't legal to drive on the street anymore. However the 300k miles it has is really showing it's age, I'm having mystery coolant losses and cyl7 is low on compression, so I went out and bought another one.
To the point. My old one, a 1995, had a u-joint front driveshaft. The new one is a 1996, with less than half the miles, and I had no idea that in '96 they changed to a CV joint. It already had a 2" lift from the PO and was used as a mallcrawler so it saw no real offroading. Well I slapped 31's on it, took it out to pilot rock trail, not aware that it had a CV front driveshaft, and promptly ripped it apart on the trail. I removed it on the trail and drove it home(after researching and making sure it was ok to do so). I then promptly did research and figured out a U-Joint conversion is possible with the various vehicles that came with U-Joint driveshafts. The only part that confuses me is the pinion nut part. I have searched and searched, probably a total of 10 hours since the incident on Saturday, and I'm still at a loss on how to do this. I found nothing on how to do it. Just people referencing it with no guides. I know it involves removing the axles, which is no big deal, as I'm going to use this opportunity to swap to XJ(I think?) front axles so I can have u-joint instead of CV front axles, so this same incident does not occur again, except with an axle. If anyone can help, or lives in SoCal and is willing to come out and help me do the conversion I would appreciate it and compensate you for your time. I have a bendpak 10k# 2-post lift so we can do it in the air, so no issues there nor is working on the ground necessary.
So just to clarify, XJ axles are the proper axles to swap to correct? I want to make sure I order all the right stuff.
I also know swapping to a 231(?) or a 242 is better, and I will be doing that eventually, I just want to get back on the trails for all the summertime wheeling, then over the winter I'll be swapping.
