I've looked at ECG and for a similar build (actually slightly more built, but not much more) it would be a *lot* more actually, even before shipping and HST. Their front 489 (basically a D44) is more in USD than the G2 equivalent in CAD and the CAD is 30% less than the USD. The G2 HP44 with ARB front locker (that is what I have now), 4.56 gears (again what I have now so couldn't change unless I wanted to do rear as well), 30 spline chromo shafts bolt in is ~$4000 USD here. That is pretty hard to beat which made me wonder if they were decent, but you guys put my mind to rest.
D44 cores here in Ontario at least are as rare as hen's teeth or so it seems. When they do come up (say out of a JKR) they are asking stupid money. Junkyards are said to be picked over, so people either upgrade their current axles, buy built new ones or go one-tons. Since I can't really build myself, I have to get a shop to do it, the G2 option seems pretty competitive. Currently the owner of the shop I have gotten 99% of my stuff down at is doing some casual looking for me through his network and comparing to the G2 option (he is a dealer as well, or atleast can source them). Either way, I will probably have him install it and do the tummy tuck at the same time. Likely over the winter when we can't wheel most trails here, so I probably need to order soon.
Today I need to do some maintenance stuff. Checking bolts, greasing, etc. I got a TMR Battery box to install and I need to fix my compressor lines as I have a leak which makes the compressor kick on all the time when wheelin and its driving me nuts. I put teflon on the threads when I redid my air setup but I must have still messed up one of the threads.
I ordered synthetic winch line, a light snatch block and some soft shackles from TRE, so that one is checked off the list.
I was also comparing Poison Spyder's full cage (~$2,000 for the welded one) to Smittybuilt's bolt on cage upgrade (~$860). Both in CAD. Normally I'd avoid Smitty, but I have to wonder if this cage upgrade is any good. The guy I have been wheeling with made his own with the TMR starter kit but he no longer can weld due to arthritis from a bad accident. He is one of our more experienced club members and has seen dozens of TJs roll and said the front window reinforcement is pretty vital.
Currently I am working for a start-up as a partner so I am not getting a salary until we get revenue coming in meaning all spending comes out of my savings. Which is to say, I am quite reticent to spend willy nilly.
My list is based on things I think are important for safety or for keeping things from breaking, trying to address the weakest parts first. My D30 is probably the weakest link at the moment as far as I can tell anyway.
07wurubi what are you running in your rear?
