1 - 3 of 3 Posts
I'm not sure as to where I should be posting this hopefully this is it if someone can point me in the right direction I have a 1996 Jeep Grand Cherokee limited with a 5.2 l 4X4 I have an issue where the Jeep will not start unless I turn the ignition on and off 4 to 6 times and only then when the fuel gauge comes on will it start once it's warmed up it will start no problem but once it cools off there the issue starts if anyone can help please do I'm going insane thank you
1st thought using a fuel pressure gauge*, what is PSI on the running engine, turn eng off and again in AM (first start) read the gauge. then see if it changes with key on. Post #'s
Have you replaced the fuel pump or filter ?
*IIRC there is a schraider type valve on fuel rail this MY.
1 - 3 of 3 Posts
