After reading bdmonst recent electric fan thread, I was wondering what the thought was on using a fan controller that utilizes the engines OEM temp sensor rather than a temp probe inserted into the radiator. It just seems it would be better to monitor the engine coolant rather than the radiator coolant temperature. I guess in a Jeep I also worry about the temp sesnor being dislodged from the radiator and not providing the proper temp reading to the controller. Does a temp probe inserted into a radiator actually have the proper coupling to efficiently monitor the radiator temperature in a consistent fashion?
Isn't the radiator temp about 20 degrees cooler than the engine, what about if it is raining hard, wouldn't the temperature differential between the engine and radiator now be much higher ?? I would think you would get different readings depending on where in the radiator you inserted the probe??
Here is a link to a fan controller that using the OEM temp sensor for monitoring the engine coolant temperature. As it is a high impedance pick up it does not affect the existing temp gauge or ECM temp input.
http://www.spal-usa.com/fans/automated/tech_sheets/FAN-PWM.pdf
Any thoughts or knowledge/experience here ?
Jim
