Edge Products Trail Jammer 2005-2006 TJ ETJ4005 [$500]
10997 8
Product Information
Price $500
Rating 4
Average Price $179.83
Manufacturer Edge Products Trail Jammer 2005-2006 TJ
Recommended Yes: 8 / No: 0
The Edge Trail Jammer performance kit delivers the ideal air/fuel enhancements for your 4.0L Wrangler/Rubicon. The Trail Jammer dramatically improves the power and throttle response of your Jeep both on and off the road. The kit includes an electronic module to performance tune your engine, a machined throttle body to improve driveability and a cold air intake system to maximize air flow. Feel the difference 20% more HP can make on your Jeep -- almost a two second improvement in your 0-60 times! Best of all, the entire kit bolts on in less than an hour.
KEY FEATURES
• Adds up to 20% more HP*
• Excellent Throttle Response
• Better Acceleration
• Improved On and Off-Road Driveability
• Increased Air Flow**
• Power to Roam that Bolts on in Less than an Hour
*Power gains based on complete Trail Jammer performance kit including electronic module, throttle body and cold air intake.
**Provides increased air flow with Trail Jammer cold air intake system installed.
1 - 9 of 9 Posts
Discussion Starter · #2 ·
Price $500
Rating 4
Pros Improved throttle response and giddy up off the line
Cons none
Recommended yes
Comments: Well this weekend I installed the Edge Products Trail Jammer kit in my 2005. I did not do their intake, being I had my own built already.
The install was very straight forward, took about 30 minutes. They supplied the torx needed. After installed I reconnected the negative terminal and started her up. Idle was just fine. So I let her idle for about 10 minutes and took it around the block. It had amazing throttle response. I did have to adjust the throttle body due it closing a bit too much. When you hit the gas it kinda stuck closed. It is just a 3/16" allen key. Now there is no hang up.
Today I drove it about 50 miles. Off the line on the highway you can definately feel the response and added torque. It does pull better at lower rpm ranges, before I was downshifting alot.
Being I only have 55 miles on it I can not tell you about fuel gains or loses. According to Edge I should see an improvement.
Will post updates in a month or so after a few tanks of gas. Being it is not my DD, takes awhile to use a tank of gas.
Rating 4
Pros Easy install, instructions very straight forward, good output/outcome
Cons None so far.
Recommended yes
Comments: Got everything (the intake, the throttle valve and the chip) installed in about an 1.5 hours. Instructions were very nice and well written. Outcome was a very nice suction, throttle response is touchy at first till you get use to it, and no whistle. I recommend this product.
Price $325.99
Rating 4
Recommended yes
Comments: Gave jeep good power gains in under an hour. Installation was brain dead simple and woke the TJ up pretty good
Price $1
Pros Better MPGs
Cons None
Recommended yes
Comments: Dont remember the price but I have noticed the difference in power and in MPGs
Price $1
Pros Easy to install, better throttle response,
Cons The new throttle body spring is very stiff, it makes it hard when wheeling when you just want a tad of throttle.
Recommended yes
Comments: I didnt put the air intake part of this product on because it looked to me like it would suck water too easy, but other than that this is a product that I most likely would not have paid for. but it was free so i jumped on it.
1 - 9 of 9 Posts
