Ok, I am a little baffled with this one. My jeep is an 86 CJ-7 and I installed a DUI distributor. Works great, I recommend it. Anyway, to get the full constant voltage to the distributor, I wired in a relay just as described here:
Classic Inlines - DUI Distributor Installation
I basically used the main red/white ignition wire going into the ignition module as 12 volt power to activate the relay when the ignition switch comes on. I also ran a 10 guage wire from the battery to the relay to be connected to the distributor when the ignition switch is on and the relay closes. Works great, runs great, just won't cut off when I turn off the ignition switch! I don't get it. The only way I can shut off the jeep is to disconnect that main 10 guage wire from the battery. I need an electrical engineer to help me with this one.
Any suggestions?
This is my relay wiring:
