WINCH INSTALL.
This installment covers SIMPLE WINCH with Dual Batteries.
Winches will draw 500 to 700 Amps (Amperes) of DIRECT CURRENT when in 'Full Pull'.
There is no generator/alternator out there that would produce that much DC energy to power the winch directly.
It would take a separate V-8 engine and a DC generator the side of that V-8 to produce that 500 to 700 Amps directly.
Not very practical to tow around an 800 pound engine and 2,000 pound generator everywhere you go!
Enter a second battery...
The idea behind a second battery is four fold.
1. Batteries store a tremendous amount of energy that is fairly quickly released, more than any automotive charging system can produce.
A second battery will increase your 'Winch' time by supply the current needed by the winch motor,
2. A second battery will keep the first (Primary) battery from discharging to the point it gets damaged.
Batteries heat up during discharge, and if you 'Pull' on one too hard, the plates will heat up and warp, touch each other, and run the battery.
3. Batteries CHARGE SLOWLY, they don't like 'Fast' or high amperage charging, so the output from the vehicle factory charging system is PLENTY to charge both batteries over time after you discharge them while winching.
4. A second battery will leave you with enough energy to start the vehicle when you are 'Un-Stuck'.
Batteries recover very quickly, and a second battery DOUBLES your starting reserve as they recover.
('RECOVER', continue to convert chemical energy stored in the battery to electrical energy after you stop winching or welding, ect.)
The one thing to remember here is BATTERY CABLE SIZE TO THE WINCH!
The winch will REQUIRE more current than the starter motor,
So you MUST use larger cables to any connection to the winch.
Starters will normally run just fine in 4 AWG (American Wire Gauge) cables,
While most winches will draw upwards of 500 Amps in full pull,
So that cable size should be no less than 2 AWG in size.
I normally OVERSIZE the cables to the winch. 'Small' cables OVERHEAT when used hard, so oversizing the cable size is cheap insurance.
Link to graphic: http://www.civilianjeep.info/Wiring/Winch/DualBattWinch01.gif
Keep in mind that WELDING CABLE is FINE STRAND wire with better insulation for this application.
Fine strand wire conducts more current, and it's easier to work with.
Welding cable has better insulation for this application than 'Automotive' wiring with vinyl insulation and thick strands.
Welding cable has a rubberized insulation that is better with grease/oil/chemicals, is better with abrasion resistance and is pretty good with UV (Ultra Violet, Sun Light) than vinyl insulated wire.
THIS DIAGRAM is the 'Simple' way to wire up Isolated Batteries with a single winch set of Solenoids/Controller.
The Third 'Starter' type solenoid connects both batteries together when you want to use the winch, no matter if the engine is running or not.
Link to graphic: http://www.civilianjeep.info/Wiring/Winch/DualBattWinch02.gif
Some EXTRA redundancy, if you forget to turn switches off, have kids that play in the vehicle,
Have buddies that 'Fiddle' with things...
