Hi! I have a 2007 WK 3.7L 4x4 with 143k miles.
At speeds of about 60 and up, there's a loud drone or howl which I'm convinced has gotten worse over the ~1,000 miles since I've owned the car. I've noticed that:
-It only happens at 60mph+ AND when I'm pressing the gas-- it immediately goes away when i let off the throttle. I can coast at any speed and there is no noise.
-It doesnt seem to be associated with RPM. I downshift to 4th, the RPM's raise, but the noise stays the same.
-It gets very slightly quieter at higher speeds (80+) but is still very noticeable.
-There is NO shaking associated with it, not even vibration.
-Brakes make no difference
-Turning makes no difference
-I cant associate the noise with a specific area of the car (front/back/side).
-I am NOT experiencing any clunk when shifting through P-R-N-D (probably not relevant anyway)
-No engine lights or anything
What I've tried so far, none of which has affected it:
-Passenger front hub/bearing was replaced, I plan to do the driver front hub/bearing next.
-I cleaned out the throttle body. It was a long shot, but I read a TSB about a whine at highway speeds (TSB #09-001-07).
-Recent wheel balance and alignment was done after installing new front shocks/struts.
Edit:
-Tires were recently replaced, with no difference to the noise.
-The noise is a low frequency, deep sound. Nothing high or squealy about it.
Edit:
