the CEL is on so lets try a scan, they are free at many auto part stores, don't know till we look.
As you mentioned a misfire can be several directions to check,
1st is always plugs, inspection or replacing.
Next lets try a can of seafoam get that at the part store when you get scan.
KNowing if there are any codes to guide us would be next.
Checkig fr a vacuum leak - use the carb spray trick for a easy check of the intake manifold.
A Diyer trick is to swap injector with another cylinder, see if code follows.
Last is A compression test.
If you are lucky enough to have a schraider valve on the fuel rail, do a pressure test then with key in RUN engine off (KOEO) observe fuel pressure drop in 5minutes, post high PSI and reading in 5min.
