does a a dana 30 have C-clips
15178 Views 4 Replies 4 Participants Last post by  purplepig
i have a 99 TJ with a Dana 30 front end and I have never had to pull the shafts out until now when i have to do U-joints. Does this axle have C-clips that i have to remove so I can get the axle shafts out?
1 - 5 of 5 Posts
Just remove the three bolts holding the hub in and pull the bearings and axles together. That will be easier than having to retorque the hub nut to 175 ft.lbs. After you remove the three bolts you can stick a 3/8" extension behind the bearing and against the housing and turn the steering wheel to push it out.
1 - 5 of 5 Posts
