Here are the final photos. All that is left to do is some detail work. It's functional as it is now.
1) Completed top.
2) New door surround upper rear mounts. Simple sheet metal that hooks over to hold the top rear corners secure against the door. That's actually a threaded bolt into the end of the tube, so that hold-off is removable and swivels when off the Jeep.
3) Side panel. Uses same technique as a normal soft top, two pieces with the proper curve, sewn together at the tube point, then velcroed to itself inside.
4) Inside top tube detail. This part is sewn to the lower side of the main top panel so this goes around the door surround tube while the top main panel goes out further to provide a mini-awning over the door top edge.
5) A couple simple velcro tabs to hold the upper rear corners together. There is not a lot of force here in wind, so not much is needed, just to deal with rain. There is another tab on the back face of the top just outside the family bar.
6) The front edge was made bikini style. The fabric was just folded and sewed 1/2" wide or so to build it up to enough layers (6) to make it snug in the normal windshield channel.
All in all, it was a tough, frustrating job. It cost me $220 for the fabric, the window panel, and notions (snaps, thread, velcro, etc). I did it because I could, had the time, and no one made what I wanted. Overall I am pleased with how it turned out and hope it lasts a long time. It is hugely easier to carry and put up than a full soft top and all it's hoops and zippers and parts. It's also really small to carry day to day when you generally ride with no top or doors all season as I do.
1) Completed top.
