I decided to build a YJ soft half-top that suits my needs. I already have a Bestop full Supertop, but it is too slow to erect and requires more hardware than I prefer to carry around in the sun on the off-chance it may rain. A windjammer + tonneau + bikini + soft doors doesn't seal well at all and also takes to much time to erect. I have found nothing in the aftermarket that fits my goals of:
That floor attachment will be optional to use. If on the trail and the weather turns sour, I can just do a quick setup of the top and snap it to the tonneau. If on-road at higher speeds, I would attach the floor straps to minimize buffeting.
The photos through out this thread got lost (sorry). These were added 11/10/2010 to show the result. Refer back here from posts below that say a photo was included. This appears to be all the ones I can find now.
This is the straps holding it tight...
Partial done mockup...
Close up 1...
Close up 2...
Close up 3...
Windshield part, slides in reg channel like a bikini top...
Completed top...
- Minimal hardware to carry, use roll bar as main support.
- Will use same Supertop connection points, so I can use full or half with no screwdriver type hardware changes.
- My tonneau can be on all the time, can stay as top goes on/off.
- Mostly weather proof, not like tonneau+windjammer+bikini+softdoors.
- Make door surrounds of 1/2" tube, just like on an OEM top.
- Freestanding (no main hoop needed) door surround will zeus fasten to the windshield area at front, plug into the full top's tub corner bracket (by door latch), and have a short strut to the roll bar to keep surround up against the closed door. (This is like a TJ surround, but the simpler YJ metal tube.)
- Final fabric will be one large piece, including the rear window. It will attach to windshield channel, run over the main roll bar between the 'family style' bars, then down behind the seats.
- The rear window back panel will secure to the floor area and snap to the tonneau (like some windjammers do).
- The rear window panel will have sides/ends on it to go under the 'family' bar and wrap around the vertical part of the roll bar forward to the vertical part of the surrounds.
- The top's roof panel will secure around the horizontal parts of the door surround.
- In general, the securing of the top to the door surround is just like a full soft top would have, wrap around and Velcro secure.
Close up 1...
Close up 2...
Close up 3...
Completed top...
