Have gotten rid of the series of pop pop pop for the most part. Loud bang if I let off the gas quickly.Is the backfire a loud BANG or a series of pop pop pops?
Matt
Matt
This is an indication that the timing chain is shot .. If the mark does not stay in one spot when idling the timing chain is bad..It is flashing but I will say not always consistently. It seems like it skips some revolutions. Put it up for the night but will see if I can get a picture if I get a chance tomorrow night.
HI,HI,
In post #3 you said
good luck take care be safe
tim
Will do, appreciate the heads up Tim and will keep you posted. I guess I am mostly hoping that isn’t the problem… hoping it is just that I am using a cheap gun or it was user error when I noticed it last time!HI, Remember if the timing marks moves around at idle or sometimes the light dose not flash the chain is bad
tim
It certainly couldOne question I have- knowing the exhaust manifold is loose on that one bolt, would this cause a backfire through the exhaust? Whether that was tight or not, wouldn’t a backfire through the exhaust mean too much gas is getting through to burn off and firing in the exhaust? Or is it letting enough air in to allow it to combust? Always happy to learn and again, appreciate all the help!
Sounds like your bolt holes got distorted and the bolt holes lose their alignment. If there’s a next time, buy some manifold spreaders. They help keep your bolt holes aligned by minimizing manifold distortion.Mine used to backfire all the time when I first got it. Replaced the exhaust manifold gasket and it doesn’t backfire anymore. What a pain in the *** though, the manifold seemed to lose its shaped once unbolted and was incredibly hard to get back on.
Good to know, thank youSounds like your bolt holes got distorted and the bolt holes lose their alignment. If there’s a next time, buy some manifold spreaders. They help keep your bolt holes aligned by minimizing manifold distortion.
