Is your timing light flashing?
Send a pic of your timing light.
-----JEEPFELLER
-----JEEPFELLER
It is flashing but I will say not always consistently. It seems like it skips some revolutions. Put it up for the night but will see if I can get a picture if I get a chance tomorrow night.Is your timing light flashing?
-----JEEPFELLER
I thought that too---then I saw it was dying and figgered he meant the distributor as a whole???
----JEEPFELLER
Im sure wiser minds will correct me if Im wrong, but rotating just the cap would cause it to die as the spark " circuit " is broken by moving the rotor away from the contacts.When rotating the distributor cap, the timing shows around 20 deg below TDC with a timing light no matter what position the cap is in. Have rotated far enough to kill the engine and the timing indicator doesn’t move. Any idea what could be causing this? Or what I am missing?
I will only laugh because I did the exact same thing the first time I ever tried to adjust the timing on a vehicle.. my buddies had a good time with me over itAnd go easy… I have been moving the cap. Realize now need to move the whole housing.Would explain why I’m not seeing a change! I guess it is likely the motor died from losing contact.
Haha thankfully there was no audience I could see! Sure it would be funny to see myself get frustrated with it though! First one so definitely learning on it. Thanks for all the help. Hoping this will fix the backfire I’ve been getting.I will only laugh because I did the exact same thing the first time I ever tried to adjust the timing on a vehicle.. my buddies had a good time with me over it![]()
The sat there and watched me for almost an hour before saying anything..
