Hey guys,
So, while i have my oil pan back off im just double checking things. And im debating on pulling my timing chain cover off again as well. (rebuild, engine on a stand)
I did the whole line the dots up, and then turn the gears to 3 oclock and 1 oclock and count 15 pins in between, and that all checked out.
I have my #1 piston at TDC, and using my old cam and sprocket and comparing it to the installed cam i realized the cam gear dot is 180 degrees out.
I turned the crank 1 rotation and that lines the dots back up. BUT, what stroke is the crank supposed to be on while dots are lined up?
Right now, if i turn the crank so that its pushing air out of the spark plug whole, once its too the top, the cam is 180 out.
Then if I rotate it while its not forcing air out of the spark plug hole the dots are lined up.
So im confused as to whether the dots need to be lined up on the compression stroke (mine are not) or on the exhaust stroke, which mine does.
Should I pull the timing chain and turn the cam 180? Do i have it on the wrong stroke.
Or am I just confused? The dots need to be lined up for distributor install right?
thanks
kov
thanks
kov
