This is a very interesting post. I have a 99' WJ, and right after I added black steel wheels and 265 tires it got the wobbles. It's not getting the wobble anymore after upgrading track bar bolts and track bar, but I feel like I can feel it want to wobble. Will disco the ABS and see how that treats it. Thanks for the info.Death wobble on a 2000 grand jeep is caused by a faulty abs circuit board..simply pull the fuse an relay shut it down before it kills you.
The front suspension design is also an issue on stock models.
The lower control arm bushings allow the castor to be thrown out once the abs pump sends high fluid pressure to the left front wheel draging not only the left front wheel at any speed.(thus causing the castor to go out of wack.once the upper ball joint is dragged in front of the lower your in trouble)
Once the above happens due to Diagonal Bar being mounted to the left frame rail to right lower diff causes a scissor affect thus causing the three things.
Axle is rotated causing castor issues (caster should always be + meaning upper ball joint behind the lower up to 10+ You do not want neg caster or zero)
Axle is dragged back on left front causing wheel base issues leading to total suspension Geometry failure.
Thus causing the left front wheel to bounce off the road violently (like an unbalanced wheel) an shake causing the automoblie to go out of control usually resulting in rollover an serious injury.
The factory will NEVER issue a recall due to Admission of guilt an thus wrongful death lawsuits.
With a TJ long arm lift kit the lower controls cant rotate however the castor is still Compromised.(although adjustable some what)
[best way to fix is shut down abs.(pull both the relay an fuse)next is too remove front diff put it on a jig table for a bridge port mill etc an ball mill the plug welds out of the centre pot to axle tubes an readjust the castor by rotating the tube in the centre section with proper caster meassuring tools an then re plug weld an install]
