I skipped the front upper control arms but I did them
x2! While the axle is in the vehicle. Axle out of the vehicle, not so hard.Note those are a butt pain to replace.
My images show the axle detached. I was able to use a clamp and my oversized sockets to press out / in the old and new parts.x2! While the axle is in the vehicle. Axle out of the vehicle, not so hard.
OP states they were replaced in the original post. That does make me wonder what brand of parts were installed. Unfortunately not all replacement parts are created equally.Are your ball joints in good condition?
Even if its dead on that won't cause his problem.Still waiting for a response on whether or not it's been aligned and what the specs are. All the new components in the world won't fix it if it isn't properly aligned.
Correct if the alignment is dead on it won't cause the problem. If it's not dead on it could absolutely cause a problem. Toe fighting itself, incorrect caster not recentering the steering, etc. People all the time install budget boosts and then cry about death wobble because they didn't have it aligned and the toe is way out.Even if its dead on that won't cause his problem.
I did mine with the axle in the vehicle. No fun at all! The replacement bushings did not include the metal outer sleeve. You had to reuse that part. So I drilled out the rubber as best I could with the bushing still in the axle. Then I burned out the rest with a propane torch while trying not to catch the Jeep on fire. I have a six inch lift so that was probably the only way I was able to have the room to do it. The new bushings went right in with a coat of grease and a hammer. It works but is not the best solution.My images show the axle detached. I was able to use a clamp and my oversized sockets to press out / in the old and new parts.
It would be MUCH more difficult w/ the axle in normal position. Still not fun w/ the axle removed, but much easier.
The Moog bushings, links and control arms are a good way to restore the vehicle so it handles like new.
Here are the parts I used.
Moog K3166 Front Upper Control Arm Bushing, Kit Includes Both Bushings
Welcome to the forum.
This reply shows the parts I used to restore normal handling.
A quick survey shows the front upper control arm bushings might not yet have been swapped. Note those are a butt pain to replace.
Note that the Moog K3166 bushings I used include the outer metal sleeve.I did mine with the axle in the vehicle. No fun at all! The replacement bushings did not include the metal outer sleeve. You had to reuse that part. So I drilled out the rubber as best I could with the bushing still in the axle. Then I burned out the rest with a propane torch while trying not to catch the Jeep on fire. I have a six inch lift so that was probably the only way I was able to have the room to do it. The new bushings went right in with a coat of grease and a hammer. It works but is not the best solution.
