1 - 5 of 5 Posts
· Premium Member
Available for Wrangler JK and JL model years! Get yours HERE!
Innovative JK Products was the first to introduce the Rear Seat Recline Kit for the JK and we are now proud to continue the product for the new JL Wrangler! Made with all the same high quality materials as the original kit right here in the USA.
We like to call it the JL Lounge! Jeep did a great job improving the overall comfort and design of the rear seat. However, this kit will allow you to gain about 2 inches of additional rear seat recline (measured at headrest) to create the rear seat JL Lounge!
1) How does it work?
The kit essentially "rocks" the rear seat assembly backwards approximately 2 inches (measured at headrest) by introducing the smaller spacers between three(3) of the six(6) main mounting points. Once the seat is "rocked" back, the four(4) front legs are lifted off the floor. The four(4) larger spacers fill in the space between the leg base and floor so the angle between the lower and upper seat sections remains the same as from the factory (and why the spacers are of different sizes). This also allows the seat to fold up and down as normal from the factory.
2) Why not more recline?
It would be great to get more recline to further improve comfort. However, it comes down to one word, SAFETY. As mentioned above, the spacers have been optimized to provide the maximum amount of recline angle without modifications or unnecessary stress to the factory components. In order to get more recline modifications would be required to the factory brackets, more stress would be induced to the factory brackets, and/or bolt engagement would be reduced at three(3) of the six(6) main anchor points. Innovative JK Products believes these are unnecessary safety risks.
3) Does the rear seat have to be completely removed to install the kit?
No: The kit is installed with the seat in place. Once the four(4) bolts on each of the four(4) legs of the lower seat section are removed (allowing the lower seat section to be raised) access is easy to three(3) of the main mounting points of the rear seat where the recline is introduced. The three smaller spacers are placed between the floor and bracket of the forward mounting point of those three(3) brackets. This is what provides the recline. The four(4) larger spacers then go under the four(4) legs of the lower seat section to fill in the gap as a result of the seat being reclined. The ratio of the amount of recline to how much the legs are lifted is not 1:1 which is why the spacers are of different thicknesses.
· Premium Member
Discussion Starter · #2 ·
10% recon coilover conversion kits
CLICK THE IMAGES TO LEARN MORE!
ALL RECON COILOVER KITS WILL RECEIVE A 10% OFF DISCOUNT AT CHECKOUT! PHONE AND EMAIL ORDERS WILL ALSO BE ABLE TO TAKE ADVANTAGE OF THE SALE.
IF YOU'D LIKE TO SPEAK WITH ONE OF OUR BUILD SPECIALISTS PLEASE SEND AN EMAIL TO [email protected]
· Premium Member
Deal of the Week - Teraflex!
All Teraflex Products for Jeep JK/TJ/YJ/LJ!
Long arm, short arm, high steer, drag link, Tera44 you name it! Email us with a product number and Rebel will work hard to get you the best deal we can.
All you have to do is shoot us an email with a Teraflex product number/website link. Emails will be responded to within 10 mins guaranteed.*
Contact us at: [email protected]
*During Normal Business Hours
· Premium Member
Dotw - rock krawler suspension lift for jl!
Rock Krawler Suspension. The Adventure Series fixed lower control arms offer a total of 60 degrees of misalignment that greatly reduces the bind inherent in JL factory lowers.
VIEW DEAL:*https://jeep.rebeloffroad.com/product-p/jlulift.htm
Rock Krawler's industry leading triple rate coils give you 2.5" of lift to clear up to 38" tires, depending on model, and improve the on-road ride over the factory linear rate springs. All Rock Krawler JL systems include correction pads that help minimize the spring bow inherent in the factory set up. The provided track bar geometry corrections, both front and rear, lets you perfectly center the axles so there is no compromise in on road handling.
System Benefits:
-Complete Bolt in System
-Excellent Highway Ride
-Improved Off-Road Ability
-Triple Rate Coil Springs
-Front & Rear Spring Leveling Pads
-Lifetime Warranty on All Hard Parts
-Upgradeable to Rock Krawler JL Long Arm
· Premium Member
DOTW - Trailgater for JK Wrangler
Image uploading. Refresh page to view
The Trailgater is engineered specifically for the 2007-2018 Jeep JK Wrangler and JK Wrangler Unlimited.
View Deal: https://jeep.rebeloffroad.com/product-p/jktrailgater.htm
It is designed to be extremely functional, ergonomic and to look fantastic on your Jeep JK.
Stop preparing your food in the dirt.
When out on the trail, most of us Jeepers end up serving snacks and meals from the top of a cooler. Quite often, part of the meal ends up in the dirt. The Trailgater is designed to get both you and your food out of the dirt.
Whether you're serving trail snacks or preparing a full meal, the fold down Trailgater utility table can handle your needs. Its large working surface provides ample room for a camp stove and still have room to place cooking utensils, mixing bowls, plates, cups, containers and such.
The slide out cutting board enlarges the working surface when needed for cooking, chopping, mixing and preparing food.
The Trailgater is also a great working surface, field desk, or just a great place to keep your tools while in the middle of a repair.
1 - 5 of 5 Posts
