Looking to see in there are any recent attempts at this ongoing and who if anyone has performed this without incident.
Currently working on a 1992 YJ and will be performing the following tasks and wanted to ask what hangups I would hit.
1.) high beams relocate to dash off wire harness
2.) Indicator lights and hazards to aftermarket switch (steering column clamp or other) - looking for this part else to dash panel multi switch
3.) windshield wiper controls to dash (switch panel)
4.) slim steering column (aftermarket)
5.) all engine indicator lights and cluster panel reworked to HUD lights dash mount
6.) autometer gauges
7.) heater vent relocate - removal of complete plastic dash and tin dash mounting backplate
8.) ignition moved to Dash
9.) custom mounts for CB Radio, Ham Radio, radio
Thusfar the plastic has been removed and working on the steering column plastic and dash plastic around the column.
pulling out all wiring to the column and working it from the connectors off the harness to a remade connector bank (not changing the original wiring harness)
Knowns thusfar
Fuel Gauge tolerances will read 1 ohm empty from sending unit 88 ohms full
Dash customization being considered requires not to reuse old YJ tin pieces and is custom made
Pneu-Con Systems Inc.
P.O Box 5715,
Bend, Oregon 97708
541-382-2552
Contact Mike Garoutte
Gauges O am looking at are from auto meter
Auto Meter
413 W. Elm Street
Sycamore, Illinois 60178
815-895-8141
Any direction or comments / constructive pointers is highly welcome
Knowns thusfar
P.O Box 5715,
Bend, Oregon 97708
541-382-2552
Auto Meter
413 W. Elm Street
815-895-8141
