I am currently Rebuilding a Dana 30 from a 79 CJ7 and am looking for advice on the Preload amount for the Differential Side Bearings. I am not asking about the Pinion Preload!
The Dana Spicer Service Manual states that it wants 0.015” of shims greater than what is required to achieve Zero End Play for the correct preload. My current setup requires 0.058" of shims to achieve zero endplay, so that would suggest I need to use 0.073" in Shims to create the required preload.
ISSUE
I just finished rebuilding my AMC 20 rear axle and the preload on the differential bearings was 0.008” in shims greater than what is needed for Zero End Play to create the correct amount of preload for the two side Differential Bearings. Disregarding that these two axles are from different manufactures. They both use roughly 3" Tapered bearings as Side Bearings and you would think the optimal preload would be somewhat similar.
I also follow a gentleman that has many years of experience and noticed he stated that he typically uses 0.005" of Preload on his Dana 30s.
QUESTIONS
1. Do I have the wrong information, or is there a reasonable explanation?
2. Is it really just a crap shoot, i.e. put some in and your good?
2. What thickness of Preload Shims should be used on a Dana 30? This is the additional Shim thickness above what it took to achieve zero endplay.
3. Looking for some technical feedback, because I am very interested in this entire process.
Thank you for your time and response. Mike
ISSUE
QUESTIONS
