Hey guys live in massachusetts and am looking at what it might cost to rebuild the 304 in my 79 cj 5. On the south shore.
Thanks
Thanks
Well, that's just a total WAG based on almost zero information... and that's probably going to be light on actual labor costs (depending on what you need/want done). I would recommend calling around in your local area to get a better read on what actual mechanics would be charging you - and not rely on some guy halfway across the country on an internet forum for an estimate.Would want it done right. Keeping it stock , no upgrades. That is steep.
I know it's not apples-to-apples, but a local (sideline, his full-time job is automotive teacher at the local high school) mechanic experienced in engine rebuilding just quoted me $3,600.00 to rebuild a Ford 5.4L 2v engine. I'll supply him with refurbished cylinder heads (I think they are $860.00/pair), new oil pump and timing set, and he is going to supply the overhaul kit and cover any machine shop work on the bottom end (obviously reassemble the engine). He's just giving me back the fresh engine, (I'm putting it back in the truck).Hey guys live in massachusetts and am looking at what it might cost to rebuild the 304 in my 79 cj 5. On the south shore.
Thanks
Just to clarify, the guy happens to teach automotive shop, but he is doing the project on his own at his home shop (not involving the students). Also, I forgot,he will be overhauling my front/rear axles as part of the $3,600.00 quote (for just the engine overhaul he would charge $3,200.00). I'm going to supply all the parts for the front/rear ends.I mean if I knew of a voc school around here that would do it , I would absolutely do that. But they sound rare these days.
This is not a bad deal since he covers machining. The axles getting new seals and bearings is also a lot of shaft removal and press work. He will probably just put all new stuff in the axles using the same old shim thicknesses but even still thats a lot of work.Just to clarify, the guy happens to teach automotive shop, but he is doing the project on his own at his home shop (not involving the students). Also, I forgot,he will be overhauling my front/rear axles as part of the $3,600.00 quote (for just the engine overhaul he would charge $3,200.00). I'm going to supply all the parts for the front/rear ends.
The part where he is doing the work is how I read it originally.Just to clarify, the guy happens to teach automotive shop, but he is doing the project on his own at his home shop (not involving the students). Also, I forgot,he will be overhauling my front/rear axles as part of the $3,600.00 quote (for just the engine overhaul he would charge $3,200.00). I'm going to supply all the parts for the front/rear ends.
Yeah you're correct. I was in auto body in HS which was next door to auto mechanics. Learned a lot but the work was all subpar and I would be ashamed to turn out that kinda work nowadays.I think jeep_boy02 meant he'd have concerns 'dropping it off at the vocational school/HS Auto Shop and letting the class do it,' rather than the teacher/mechanic doing it 'on the side,' as you mentioned.
