That sounds like the classic weak fuel pump or worn pump relay, but changing the relay is easy enough and simple. You need to measure the rail pressure to be sure.
Otherwise an intermittent open circuit on the relay coil-connector-harness which, in turn, caused the relay not to energize when expected (throws P0688). Could also be the relay or PCM. If replacing relays don't work out, check for corrosion in the PCM connector.
