1 - 16 of 16 Posts
How much did this cost you? I realize not all shops are the same...
99 Quadra-Drive WJ 4.7
I'm positive ours needs it. Over a year and a half ago we began experiencing a roar, then backing out and turning it would make grinding noises. Now 75% of the time it makes god awful noises when turning. I'm gonna pull the front diff cover soon and inspect it. The rear diff is fine.
Don't be surprised if you get quotes around 1k...
Start calling around to wrecking yards and u pull its. Not a difficult thing to swap in a junkyard axle.
Did my front pinion bearing for $600 at a dealer, would have been cheaper at a non dealer shop.
Years later and more knowledge, my rear end was out of spec and going out. Paid $100 for a craigslist axle, installed myself with a friend in about 3 hours, trouble free for the last 2 years. So I would suggest craigslist/junkyard. What exactly is wrong with yours? Could it just be spider gears? or did you blow it up? If you tell us symptoms etc it might save you some cash.
I got my front axle completely rebuilt with all new components, gears, bearings, seals, axle shafts, the whole nine yards.... set me back roughly $1300 from the dealership
the quadra drive's front diff is $700 for the entire unit and you can only buy the entire unit (non-serviceable). so yeah it cost me just over 1k to get my rear done at a local shop. and i think that was with a used unit.
Discussion Starter · #9 ·
So a brand new unit is $700? I can't imagine it being that difficult to replace the entire assembly.
Got Beer?
Are you sure it is the differential? Have you checked your axle CV joints? How close are you to the Detroit area. I can recommend a good Ring and Pinon shop here. Also, I recently had a grinding noise and thought it was a CV joint, but turned out to be my front drive shaft.
As said above, you should check your cv joints. The fact that a lot of the noise is bases on turning makes me think cv
You can only buy the complete unit. it cost me ~650 for a used one. you can find quotes for just the diff in the neighborhood of $700. it really sucks. so yeah check Everything else before going that route.
Got Beer?
A new Detroit Tru Trac for a D30 is only about $450 at the ring and pinon shop. And I would not try to install it yourself unless you are experienced at it, because if you do not install it correctly it will wear out the gears quick.
http://www.eaton.com/EatonCom/Produc...trac/index.htm
another thing it says in the Manual! for the Tru-Trac DOESNT REQUIRE LIMITED SLIP Additives
that would sell it for me 10x plus use's Worm gears no little clutch plates and crap to wear out.
Discussion Starter · #15 ·
They are brand new.
On a good note I think it may not be the differential after all. I decided to do a wheel bearing check and there was WELL over an inch of play top to bottom on the drivers side wheel. It felt extremely loose and made some metal noises when doing so. Gonna order a timken replacement on ebay for $78 tonight and get that on there. I have a feeling that will take care of everything, and hopefully the roar I've had for a year and a half.
Discussion Starter · #16 ·
All grinding noises are now gone as a result of replacing one of the wheel hub assemblies. There is still a slight noise but now it seems to be isolated to the back passengers corner so I'm wondering if there isn't another that needs changed out.
At a small cost of $78 per timken bearing, do you reckon it would be worthwhile to go ahead and change the other 3? Also, some of the noise may be attributed to the wrangler gs-a tires as well I suppose. I so used to my daily driver, a buick riviera that I'm accustomed to pure quietness lol.
1 - 16 of 16 Posts
