82 cj7 4.2 engine w/ front power disc brakes. trying to wrap up the little things after finally getting it running. Several issues along the way have been fixed with all of your help and nearing the end of the restoration and after finally getting it running but not completely drivable yet for any distance I noticed that the brake pedal doesnt feel right.. not good pedal. I have replaced cylinders and shoes in rear and adjusted to a good point which I know is where the pedal feel comes from so this leads me to my ? along the way it has been discovered that I had recd the CJ with the wrong master cylinder/booster set up and had to replace the booster to accommodate the TBI conversion when I discovered the existing master cylinder is for 4 wheel disc brakes so I left it in place because it did not bypass when brakes applied but now wondering if I need to get correct cylinder for front disc brake car? Could that have an effect on the pedal feel? AND does it look like the brake line diameters off the current master cyl look correct or was that changed also by previous owner? See pics of mc and the set up when i got the cj
, thanks Mike
, thanks Mike
